fatboyelroy
10.28.2009, 04:47 AM
(4) 1527 1.5d's are NOT within reason
Hey FBE, what voltage you plan on running, What packs ETC ?
Curious to the layout of the drivetrain for 4 BL motors ??
Thank you guys for the input and enthusiasm. I will probably end up using this brake set or these with some modded aluminum hubs and axle carriers.
I am not sure if I want to use a123s or lipos. I want to keep it at around 6s.
I will be using an E-maxx aluminum flm tranny case and gmaxx single speed conversion with a set of ultramaxxed Gen III metal gears. And yes an upgrade to the diffs is a must.
