Pdelcast
Pdelcast's Avatar
10.28.2009, 10:44 PM
Correct me if I'm wrong here Patrick.
I believe individual ESC settings are retained as Eprom data inside THAT individual ESC.
The Castle Link first reads the data from the controller, then displays it for your viewing pleasure. LOL
Then you can change what you like and rewrite that data to the controller.
When you hook up to a different controller, it firsts reads that ESC's stored data, then the process starts all over again.
It's a very good system IMO.
Yes, that's true. The settings are stored in a flash block in the processor.
We always suggest that you save any settings files you wish keep prior to doing a software update, but the software will write your original settings back to the memory after a software update. However, rarely something will go wrong (like the programming gets interrupted) and that can cause a loss of the settings. If you save them to a file, you can always update them again after an aborted software upload.
Patrick del Castillo
President, Principle Engineer
