10.29.2009, 09:37 AM
If all the cells voltages are in check, then the problem might be the balance plug ?
I and several friends have had problems with various packs balance plugs, they just refuse to make a connection with charger/balancer.
The fix is soldering on a new balance plug.
The new plugs w/wire can be found at MaxCramps for 1.99 E.
