Originally Posted by suicideneil
Absolutely stunning build there dude, and it goes like a rocket... a very small rocket...
On the custom chassis front, have you taken a look at this build:
http://www.rc-monster.com/forum/showthread.php?t=23804
I know its aluminium, but the same principles should work for a CF version
Yup! Kaz gave me a lot of insight and has helped me out a lot on this build! The problem I have is the chassis has a kickup in the front and a slight "kickdown" in the rear. I'm not an expert at CF so I'm not sure if it'll be ok to heat it and try to bend it. There's a guy on another forum that made one using the stock upper chassis bolted to a bottom plastic chassis. He just cut off the battery compartments and the surrounding area of the chassis mounts. I might look into that design. It'll be easier but not as "cool" though
On some other news, my speed gun came in today. Now I just need a smooth straightaway and a camera man!
