sikeston34m
sikeston34m's Avatar
10.31.2009, 05:47 PM
I just did a quick test with various loads with the BEC set for 6v:
5.94v unloaded
5.76v @ 0.48A
5.72v @ 0.64A
5.70v @ 0.95A
5.63v @ 1.87A
4.16v @ 2.77A
Not sure exactly what point the BEC voltage hits its max, but I would say right around 2A. As you can see, the output falls dramatically somewhere around there.
Thanks Brian,
This explains what I witnessed.
A High Torque Servo is likely to draw more amperage than this, especially when fed more than 5 volts. And especially a Pair of High Torque Servos.
Hmmm....... I thought the Internal BEC would be more beefy than this.
Is this a firmware issue? I was running version 1.2, since I read there were motor starting issues with version 1.3.
