sluggie24
sluggie24's Avatar
01.28.2006, 05:09 PM
I hope the drivetrain will be ok. Will have strobe slipper, flm tranny case + idler gears, carbon steel driveshafts and axles, integy diff cases with flm diff cups and 3 mm screws, airtronics 94358Z steering servo, traxxas big bore shocks with team blue star progressive rate springs, aluminum custom wheelie bar, and rubber sealed bearing replacing all the stock ones everywhere. I left the rest of the truck stock as it seems pretty tough and light.
I do question if the rear diffs will hold up under prolonged use though..... anyone have any experience with a set up like this and breakage problems?:confused:
