My 2cents -
11.06.2009, 06:47 PM
RPM would be the best bet for the RC10.
If you install aluminum arms then the bulkheads will be the weak points. Aluminum bulkheads and aluminum arms will cause the pins to bend and or shear and the arms will bend anyway. (with a hard impact of course)
With RPM, 9 times out of 10 the chances are the truck will bounce off the inmovable object and motor away.
