sluggie24
sluggie24's Avatar
01.28.2006, 05:59 PM
Hey Nick, do you think 18 cells would be better than 20? I really don't feel like cooking $300 worth of parts by giving too much power. I'm gonna use 4200mah batteries so I was hoping for around 15 mins of runtime at least. The way I'm gonna set it up I can run 14 cells or 20. Does run time go way down the more cells you put on? I would have thought it was the other way around given a proper gear ratio. If the torque is too much I should just be able to get a larger pinion to compensate correct? I ordered 16 and 18t pinions with the 51t spur. Could always go higher as long as the electronics don't cook right? mmdooley, you will have to let me know how it goes on yours.
Maybe Mike can give me his input on this setup???? I think I need it.
