sikeston34m
sikeston34m's Avatar
11.09.2009, 12:25 AM
Originally Posted by asheck View Post
Unfortunately, this is a great idea, that several, including myself, have tried and failed at. At least to get any kind of usable speed. Problem is driveshafts, once you get a locker, because nothing else will work, they will twist. Stock's, Jato's, MIP's, even the FLM's will not hold up to the power of 3s, and truggy tires. Since all the weight is in the rear they actually get very good traction. The only thing I've come up with is custom driveshafts. If your willing to go slow, under 35, and use a loose slipper it can work. So good luck man. :D
Smaller Tires will take the place of a loose slipper and not put so much stress on the drive train.
