11.09.2009, 01:02 AM
Yea, I have as much weight far forward as possible includng the batts. Like I said I might rethink the front wing design. But putting the throttle curve back to stock and 90 or 100% punch control should do the trick. It only came up when I went over 80% throttle also. To much power added at 80% throttle on the curve I set up. Basically it didn't work the way I though it would. A more linear curve should be alot better.
