Freezebyte
11.10.2009, 03:17 PM
Another thing is maybe don't charge to exactly 4.2v/cell. I set my CC/CV threshold on my charger to 4.15v/cell. You lose very little runtime but that extra 0.05v/cell gives you a little wiggle room in case the balance is not perfect. That way, there is less of a chance for a cell to exceed 4.2v by the end of the charge.
Wouldn't that be made irrelavent if your balancing your lipos on every charge like I do? My Triton2 charges via the amount of maH the battery is designed to hold, not voltage other then the default 7.2v lipo cell setting which tells it was size of Lipo im using. This however doesn't limit my charges via voltage, just mAh, at least thats what the Triton2 goes by, is probably different for every charger and i've never seen my cells go beyond 4.2v or 8.4v once its completed charging. By changing my MMM LVC to 3.5v, ive been leaving the lipo's around 800mah left in capacity ass soon ast the LVC kicks on. Which is a little bit more then the default Lipo 80/20 rule, but I have better things to do then carry a freaking timer on me when im bashing and having fun
