Pdelcast
Pdelcast's Avatar
11.10.2009, 07:39 PM
Originally Posted by Freezebyte View Post
Wow, no wonder I couldn't hammer that sucker out, it didn't even budge. I'd basically have to destroy the bearing to replace it then? I took it to the LHS and my main guy their said it makes a little bit of noise and some resistance but it should be ok for a bit longer.
I should probably take a movie of me spinning it and you can tell me how good or bad the bearing is.
EDIT: Heres the video, tell me what you think. And whats up with the shaft being able to move back and forth like that? Is that bad?
Well,
The bearing doesn't seem to be bad -- it will have a little resistance to turning because of the bearing shields.
And it looks like you lost the front bearing spacer -- it's not in the video. That's why the shaft moves so much.
Patrick del Castillo
President, Principle Engineer
