11.11.2009, 02:36 AM
Originally Posted by fastbaja5b View Post
Stock gearing, stock tyres, 4s lipo a standard launch is 120ish amps
I tested a pair of freshly charged Reedy 5000mah 20C packs and they dropped below 3v/cell on take off, that told me the battery wasn't up to the task.
Conclusion?
5000mah 20C is insufficient for the Savage Flux.
Well, the conclusion is that reddy 5000 20c packs are not up to task... I ran some old 4900 20c trakpower packs on a 4s savage 25 that I converted and they were OK, but they did get hot. 4s in a MT is a poor idea anyways, but you need good packs if you plan to do it.
Originally Posted by Gdot View Post
I damaged 99 amp batteries setup with the flux all stock 2200kv on 4s. I don't think 100 amps is enough.. I have 150 amp and up batteries for them now, and it's perfect. No warm batteries or anything of the sort.
150 amps for any 4s heavier setup (1/8 buggy and up) is a wise move. That will allow you to gear however you want and have headroom. If you want to use those 20c packs go with 6s 5k 20c and just gear it back down to 40mph or so (move volts and same overall speed equals less amps).
Originally Posted by speedy View Post
with stock gearing and 4s the cc-2200kv motor won't pull more than like 90Amps right ? if it pulls 120-130amps on 6s with that gearing ?
You cannot lower the voltage and expect the amps to go downs as well... Yes, a 6s setup will go faster than the 4s setup will with the same overall gearing, and yes it will draw a bit more due to the addl wind resistance and drag associated with higher speeds. But you can pretty much consider the amp draw will be about the same with the 4s and 6s setups.
Consider 120amps at 4s lipo is about 1800 watts. And say that 1800 watts gets you 40mph. Now add half as much voltage again (up to 6s) and you get 2700 watts. If you maintain the gearing you should get half as much speed again as well, 60mph. Now in the real world you will find the 6s setup can maintain voltage better under load, and that is about negated by the addl wind drag and other resistance from going 20mph faster. So it is a wash, the addl power gained by going to higher voltage is cancelled out by the need for more power to achive higher speed.
You need good lipos to run 4s in a heavy vehicle and really be able to push it. That is why all of these "crap" batteries are failing in 4s setups. Seeing all of these early life cycle failures from smc and the other "name brands" are not surprising to me. Overrate a pack, and a 4s MT with an aggressive driver will show you the real limits of the pack.
For this reason I went up to 6s in my trucks, and gear for mid 40s. I se no reason to not do this with the flux, as you can get inexpensive 3s packs that will fit the batt boxes, and tossing on a smaller pinion costs about 15 bucks.
Just my 2 cents, but they cost me thousands in lipos to come up with...
