PBO
RC-Unobtainium
PBO's Avatar
11.13.2009, 02:54 AM
Last few I ran did not keep up, not dragging, on the interstate, down 2 lane twisty road (no hills in LA, pretty flat). Ran a few regular wrx and a few sti models, the sti were much closer. I do know how to drive overpowered rear wheel drive stuff, so maybe I had the edge over the spoiled college boys in the subies? Who knows, but they are familiar with the ford's tailights.
On a track, or with comparable drivers, the difference would really show. A 4wd low cg car should easily best a 2wd truck, but so far I am still in front. Seemed like I was pulling harder on the straights, and not wussing out as hard on the corners. My truck does have 285 nitto rubber all the way around, if that makes any difference.
There's some funny stuff in there...I'm picturing you running moonshine
If you're only using 'college boys' as your measure...well there's your problem. It takes a while before you learn to drive a turbo Awd fast. Go find an experienced driver who isn't still learning to change gears, then tell me who's faster
Enhanced Rustler 1515 1.5 MMM
Losi 8ight-T
