SpeedAssault
SpeedAssault's Avatar
11.13.2009, 12:35 PM
Originally Posted by littleazn248 View Post
Hi there I noticed that you're using a custom chassis what are the dimensions? I'd love to do a similar project. So will Road Rage tires fit in the wheel wells of the body? By the way i also noticed you live in the Bay Area are you part of the M2 Hobbies forum yet?
Thanks
Sorry guys haven't been here in a while, I got an email notice from here, so I'm back now. with the car breaking so much I got a little distracted and built my Berg Crawler.
If you Use the monster size Road rage tires you would need to cut the wheel wells just a bit, i think those tires are like 6", should be some really great traction though.
Tell me about " M2 " I am not familiar with it.
Long live the E-Maxx in all its forms! Have been watching the build all along! Its great! How is it going?
Yea, they seem to be made into many different things including crawlers.
hmm i've been doing some research and cant seem to fine the wheel adapters you are using towards the end i see the OSH ones but i want to get ones like you use towards the end. You are using FG racing wheels right?
YEa I know they are very hard to find. They are Losi quick change adaptors part number LOSA2996 .
I also built an Off-roader, stretched out my RC10 GT (gas) since the engine was toast I made a electric engine mount and swapped in the Mamba MOnster and Castle motor, it's a blast to drive.
Back to the 1/5, I have the car back on the bench now and put the ESC back in. I bought a double set screw Pinion gear and added loctite, seems to be doing the trick. I need to replace the Front and Rear Bulkheads as they have endure damage from crashing.
SHould be able to get to that next week. Looking forward to getting it back on the road.
I am in Campbell and not far from the RAMS club Fremont College 1/5 races near Great America
I found the Black wheels on Ebay, used $50. but they don't have enough grip for this 6S so I am thinking of grooving them. I contacted FG supply they recommended these
Hope that helps
Oh the chassis dimensions : well it has many angles but the widest width is 7", total length 27" , between the arms under the diffs is 2 1/8", wheel base 20.5"
Anything else ?
