Pdelcast
Pdelcast's Avatar
11.13.2009, 02:31 PM
You should have a "newb" controller with a static 1 ohm resistor in series with each motor phase. Would help tame those current bursts, but not sure what adverse effect that would have on the ESC.
We are planning to put a "newbie" mode in the next version of software -- where you can quickly program a "limited power" mode on power-up. This will limit output power to say, 50% of normal power.
I'm thinking that when I take out my electric Baja, I can run it in "normal mode", and then let my 8 year-old daughter take it out in "newbie" mode -- and I won't have to worry about it as much.
What do you guys think??
Patrick del Castillo
President, Principle Engineer
