Pdelcast
Pdelcast's Avatar
11.13.2009, 04:22 PM
I like the idea. But, won't that be the same as simply turning down the throttle EPA on the radio? And your FAQ page specifically says not to do that. I can't think of any other way to programmatically accomplish what you are talking about. Personally, it would be easier to simply use less battery voltage and dial in 100% punch control.
Now, when you release your ESCs with data logging, you could use the current measurements to automatically dial in punch control and maybe even some EPA to keep current within reasonable limits.
The FAQ page says not to use the EPA because we don't want people setting up a system that draws, say, 400A at full throttle, and then using the EPA to limit current...
If currents are fine at full throttle (are within reason...) there's no reason why you couldn't use EPA to limit throttle levels.
Patrick
Patrick del Castillo
President, Principle Engineer
