sikeston34m
sikeston34m's Avatar
11.13.2009, 10:50 PM
Originally Posted by Gee View Post
It would be nice if there was an easy fix for the locked rotor. I've gone through my share of HV ESC returns for warrenty issues. This one is out of warrenty and it just up and quit working one day. I would be more open to spending some money on it if it was one of my screw ups or atleast had some fun do it. Can't hurt to take the rotor out and give the inside a cleaning. Might help. Thanks for the tip.
When you open the motor, look all the way down inside the hole the rotor comes out of.
You will see a circuit board with several components on it. There should be three little black squares, 120 degrees apart.
I have a motor here that lost one, and it behaved like you described.
I've been thinking about sending it in for a Non-Warranty Replacement. There's no fixing it.
When you put the rotor back in, be VERY careful not to hit those hall sensors with the end of the rotor shaft. They can be damaged if not careful.
I hope this helps. Gee, you have a PM.
