sikeston34m
sikeston34m's Avatar
11.14.2009, 11:47 AM
The low voltage (8S) ICE will be available in a 150A and 200A.
The high voltage (12s) ICE will be available in a 125A and 160A.
The low voltage ICE will probably be limited to 6s in car applications -- the switching BEC is similar to the one used in the MMP. Even though it is rated for 60V operation, the braking energy can still be an issue.
The HV ICE doesn't have a BEC (it is Opto) so will probably still be good up to 12S. We still have to do some stress testing (especially on braking) once the software is done, to verify that it will work up to full voltage as a car version...
Patrick
Hi Patrick,
Thanks for your answer.
Do you have plans to allow the Mamba Car Software into the currently available ICE lineup?
The 50 amp, 75 amp, and 100 amp versions?
