lutach
lutach's Avatar
11.15.2009, 07:43 PM
Originally Posted by NovakTwo View Post
Links, please
Here's a link for the Castle products:
http://www.castlespecialprojects.com...ntrollers.html
Now the rating for the MM Pro might be with the older FETs they had or it might be just a safer rating to avoid people going over what the ESC is actually rated for.
This is what I found for Tekin, but Jim has said the specs in rc-monster or rctech, but I'll search for it and post it.
SPECS: Controls: Forward/Brake/Reverse
ON Resistance: 0.00005 Ohms (brushed fwd mode)
0.00015 Ohms (brushless mode)
0.00015 Ohms (brushed fwd/rev mode)
Input Voltage: 4 - 9 Cells, 2 - 3S Lipo
BEC 6.0 V / 3.0 A
Motor Limit: Brushed and Brushless, no limit
Throttle Profiles: 1-7
Max Current: Brushed Forward, 312amps / 624amps (R1 / R1 Pro)
Brushless per Phase: 104amps / 208amps (R1 / R1 Pro)
One thing that I was thinking is to see if Novak, Castle and Tekin to form some sort of standard rating based on data from in-house testing and race pace with some sort of data logger available on the market (Novak and Eagle Tree for example). Either make a website or post it in various forums and hopefully others will join in and end the higher ratings. Even though they are your competitors, it would be nice to join together to form the first hobby industry standard system of ratings. The some one will have to figure out how to do the same for lipos .
