Size motors to use with MMP -
11.15.2009, 10:12 PM
I have been reading around and noticed that it was mentioned that the MMM’s warranty would be void if the motor used was less that 70mm in length for a 36mm diameter motor. I guess the same would be true if a 2200 or the 2650 was used with the MMP? What are the recommended motors for use with the MMP and 6S? I don’t think any of the current available CM-36 motors (4600Kv-9000Kv) would be a good choice to use with 6S.
Jeff
