11.16.2009, 10:47 AM
Originally Posted by Rusteh101 View Post
You would be turning half the RPM that you would on your 4s Hyperion batt, so it would be slow and also draw quite a few more amps unless you lower the gearing ratio.
Actually, if he doesn't change the gearing at all, current will be reduced by about half. Halving the voltage on the same resistance (mechanical and electrical load) will halve the current. But yes, it will be much slower. However, if he gears up to compensate for the lower speed, then yes, the current will go up a lot.
