11.17.2009, 04:54 AM
I would go for the 4000mah one.
I have no idea what fits or not though (sorry).
But from a quick glance, here is what I saw.
The 4000mah is rated 25C (so that's 100amps) while the other two are 30C.
The 3300 30C means 99amps, which is more or less the same, but you are paying more for less capacity - I see no point, so that one is out.
The 5000mah one costs more than double than that of the 4000mah one, though, of course, it provides much more current (5000mah at 30C is 150amps). However, I don't think it'll make much of a difference unless your pede is 10lbs and geared to 80mph.
So, based on that, I would recommend the 4000mah one. It is the cheapest and provides plenty of juice (assuming the C ratings and what not are accurate).
