Seems to me
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Seems to me - 11.17.2009, 10:13 AM
Seems to me that if you have less torque you would have less of a load, but would it have enough to[ end power to get you up to speed considering the short distance you are traveling on a drag strip? Plus your wheel spin seems more related to your weight being too lite. Thats why they use such extreme down force on drag strips to get the power to the ground with less wheel spin. You could also use wheel warmers, which will give you better traction from the starting line. Your lucky you got to see some of the reall speedsters out there, and hopefully you learned a few more ideas from their setups.
SUPERMAXX YOUR LIFE.
