Brushless Motors and Speed Controls for sale
Brushless Motors and Speed Controls for sale - 11.17.2009, 11:14 AM
Ok, last of my "inventory" here.
Hacker c50 motors. Great motors, plenty to power 1/8 buggy or an emaxx. Both of these motors would be great for a 4s setup. I ran them both in a hyper buggy on 4s and it didi very well, good temps and plenty of power.
C50 8L 3000kv
C50 MAXX 3000kv
The c50 15l is sold!
(2) Aveox 27/39/1.5 motors, 1/8 shaft 16/19mm bolt pattern, 2100kv
Hacker A30 8xl outrunner, 5mm shaft 1100kv
4th motor is another pic of the reedy, which is sold.
Feigao 14xl. 1200kv, 5mm shaft. This motor is brand new, never run or mounted!
Quark 80 air. 80amp esc. has a few different profiles for air heli use, and you can use it as a forward only esc (if you run mech/no brakes). It will program to a wheel radio with no issues or tricks. Has a small bec harness wired to the main leads with a micro deans, regular deans on the main leads and 4mm female bullets. Box and instructions will be included.
(2) Quark 125b escs. Both have ccbecs wired onto the main leads and the red wire removed from the signal harness (just unplugged and folded over with some shrink over it.) Box and instructions will be included for both.
