SpeedAssault
SpeedAssault's Avatar
11.17.2009, 06:46 PM
Originally Posted by littleazn248 View Post
Thats good because i might go with a twin setup. Since I hear that the ezruns aren't as powerful as the MMM i figure why not use two ezruns. However, it sounds like your breaking alot of parts; so are you breaking the center drive? Im don't quite remember reading but did you try just using the plastic slider shafts instead?
By the way how did you fit on revo arms? Also i remember hearing you said the car was to wide standard. So did you have to drill deeper so the ball joints could go in further?
Thanks
Dont follow you on the twin setup..?
I have broken a tooth off the center spur gear, mod 1 51 tooth steel.
I upgraded to Losi center diff but locked it up with a steel block inside and a pin.. and upgraded to LOsi center diffs. Front with 5000wt, rear is locked. I used Losi gears but I cut down the stock traxxas ones, it's in the thread somewhere. the modified output shafts is what the revo drive axles connect to, they are doing great.
Page 2 http://www.rc-monster.com/forum/show...6&postcount=57
The revo arms fit with minor trimming of the emaxx bulkheads, but after a collision the bulkheads broke so I am putting the strong grey ones and Ditching the titanium screws and using 5/40 steel screws.
I cut down the arms by 1/4" and re-machined the inside of the 1/5 wheel square hub by 1/4". pics in thread
