11.18.2009, 06:48 PM
Are Mike's mounts not sturdy enough? If you feel they are too small, I'm sure he can work with you to make a special uber-tough one if needed. Cost will probably be initially higher for the custom work, but might save you money in the long run replacing spurs, bearings, etc (not to mention the time required to do the work).
