Riko
Riko's Avatar
11.19.2009, 09:34 AM
Originally Posted by fatkidjoey View Post
well i ran the MMP in my 1/8 buggy D8 and all i can say is WOW ! smooth and fast no heat problems what so ever ! here is my set up
MMP
castle 2200kv
hyperion 4s 5000 g3
15t pinion
50 spur i think what ever stock is
the motor never got up past 100 and the esc would come off at 115ish after 7min
hats off to castle you guys did a great job !
but the bullet connectors for the 2200motors are 6mm and the bullet connectors on the MMP is 4mm, so you just soldered 4mm bullet connectors on the 2200 motor cables?
other question:
4mm = up to 75amps and 6mm is up to 6mm amps.
What does that difference do to the relation ESC - motor?
You've been hit by, you've been struck by a smooth criminal
  Send a message via MSN to Riko
