jhautz
jhautz's Avatar
11.19.2009, 10:21 AM
Connectors can be changed. All you need is a soldering iron. Heck... You don't even need to use connectors if you direct solder. Not sure what your question is?
All CC is trying to say is don't overload the esc. They can both run a 1/8 buggy or as large of a motor as you want. It's just the amount of load you are putting on it. Lots of factors go into figuring out what the load is/will be. If you don't understand I would reccomend just getting the MMM if your car is a 1/8 and getting the MMP if it's 1/10. That's why castle speced them that way.
to make it...
or break it...
Silent...But Deadly
