11.19.2009, 01:45 PM
Use a dremel to cut a slot on the screw head, then use a flat blade screwdriver to remove the screws.
You can cut small sections of fuel tubing and insret it in the drive cups to take up the slack in the center driveshafts. My hyper 8 has some slack, but not much.
