Unsullied_Spy
Unsullied_Spy's Avatar
11.19.2009, 09:40 PM
Originally Posted by Riko View Post
lol so, can somebody sum up for noobs? :D
MMP (1/10 esc) + small motor (for 1/10) = good combo
MMp esc + larger motor (2200kv) = bad...because
MMM (1/8 esc) + small motor (for 1/10) = bad...cause
MMM + larger motor (2200kv) = good combo
MMP + Larger motor = Bad when used in the wrong setup, in 1/8th setups I'd use it only on 6s with lower KV motors when your peak power output is less than 2,000 watts (keep the amps down).
MMM + Small motor = OK. Small motor + big truck = bad. You won't hurt a motor or ESC by using an overkill ESC.
