Originally Posted by J57ltr
Ok it wasn't you it was Joe and it was 68mm not 70. I guess I remember seeing the Castle logo and since you were the last one to post I thought it was you.
http://www.rc-monster.com/forum/show...ght=warrantied
I would like to use the MMP unless you recommend against it. I would also like to keep in warranty at least until it is up. I need something smaller than the MMM combo to keep it under the buggy body, there isn't a lot of room under there. Since I don't plan on bashing around with this car (at least with the same setup) so would be recommended for this application?
Jeff
AH! Joe was basically saying "
Don't use a motor that is too small for the application!" cause it will fail, and take the ESC with it...
It's fine to use the MMM in a smaller application -- as long as the motor is sized appropriately.
