sikeston34m
sikeston34m's Avatar
11.20.2009, 07:30 PM
Ok, so I got my turnigy 2s2p pack in today. Looks good, but i will give it a test in something, maybe a novak gtb with a 3.5 in a 10th 2wd buggy? That should put a load on it, geared for 60 or so...
That's a good test bed for it.
I think you'll see, they don't mind a big amp load at all.
My 2S2P packs went through some more testing today.
This time in an E maxx using a Novak HV Motor powered by a MM Pro.
The MM Pro is smooooooooth in sensored mode.
What I did different with testing was:
Using an AUTOMOTIVE type charger, which yields a 14.5 volt charge cutoff, I recharged the packs in series, at 20 amps!
The entire recharge took less than 20 minutes! I did monitor cell voltage with a meter while recharging.
They didn't mind this treatment at all. The packs were cold when the charge cycle started, and cold when it was done.
I was tempted to kick the charger up to 40 amps. Hmmm.......should I try it?
40 amps would be about a 9C charge rate.
