mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
11.21.2009, 12:20 AM
Originally Posted by shaunjohnson View Post
yeah, add to the eagle tree data on the same packs that is floating about and you have mega data!!
too bad the CBA only does 10A right?
It depends on the number of cells you plug into the CBA. It let me test at 10 amps for 2S but would ask me to go down to 5.9 amps for 4S. A Techy could probably answer why. Westmount Radio is the company that makes the CBA. They also make 500 watt amplifiers to use with the CBA. That's 120 amps you could test one cell with. They also talk about a harness to be able to use up to four of those 500 watt amplifiers for a total of 2000 watts so that's like 476 amps is it? I hope I'm explaining this the correct way. I kinda read quickly through their description on their site.
Those amplifiers are a bit pricey though at $730.00
No brain, no headaches.
