11.21.2009, 01:09 PM
Those seem to be stock older maxx size tires- Imex is pretty good with their info- each tire is in a different size class (highlighted in bold as you scroll through the various different designs), and when you look at the rim choices, you see the same size classes:
Rims >
» 1/5 Scale
» 1/8 Buggy Rims
» 2.2 Rims
» 2.8 Rims
» 26MM Rims
» 38 Series
» 44 Series
» Clod Buster
» Truck Rims
» Truggy Rims
Tires >
» 1.9 Series
» 1/5 Scale
» 1/8 Scale Buggy
» 1/8 Scale Truggy
» 2.2 Tires
» 2.8 Tires
» 26 & 32MM Tires
» 38 Series
» 44 Series
» Blackfoot
» Clod Buster
» Jumbo Truck Tires
» Rock Crawlers
» Truck Tires
If you look under 'truck tires', then they are all pretty much designed for either jumbo sized rims (the huge wide ones like I use), or standard older maxx rims (the normal sized looking tires).
