redshift
RC-Monster Square Tube
redshift's Avatar
11.22.2009, 01:16 PM
Well I actually just rebuilt my 3906 trans. I wasted 2nd gear by shifting under too much power... I made it over a year without doing that. I am still using the nylon gears, but I have UE idlers. I only run a 9XL/4S so if I'm not stupid the trans holds up very well. I did also use a small amount of silicone to seal the case halves. As long as the fluid level is below the output shaft it should stay put.
You say cam lube, are you referring to engine assembly lube?
