01.30.2006, 01:42 AM
I have no experience with 14 cells, all my racing was done on 12 cells, but I can tell you i'm close to 30 with 12. I broke in all my titans with a power supply at 6 volts for 30 minutes and used Prolong oil treatment on everything (bushings commutator and bearings in the truck). In the Emaxx i could keep up with a nitro Tmaxx (TRX.15 not 2.5)on our little track. I have not done this to my G2R yet but i can still keep up with a stock revo on the same track (thanks to the supperior handling. The gearing i used then and now is 18/66 but with 14 cells i would go with 16 tooth pinion with a 66 spur. Let me know how it runs with 14 cella i might do it when i get better cells, all mine suck bad.
How did you get it down to 9 pounds? I just swapped over from a revo and mine weighs 12 pounds RTR with batteries
