Thread: evx and lipo
11.23.2009, 03:15 PM
Ah, that could be slight issue, but there is a work around, of sorts. You would need to buy a single 2s lipo male balance plug (jst-xh/ align style) with the wires pre-attached, and solder it (first & third pins/wires) to one of the esc's battery connectors ( refer to that diagram I posted earlier to work out which one). Then, you would just need to plug in the lvc device to that balance plug to monitor your lipo during use- you wont be able to read the individual cell voltages though since you cant hook up all three wires on the balance plug, not unless you add a little bullet plug to the middle wire and plug that into the little hole on the lipo ( I take it you have hard case lipos that have 2 large and one small female bullet built into the case?).
