Originally Posted by lutach
Clay flower pots, ceramic containers are good, but what's bad is the smoke. If your back room got filled with the smoke, there will be a high chance of many metal things getting corroded. Forgot to ask, did you inhale the smoke?
Lutach is there anything I can do or should do help prevent the corrosion. Is it the chemistry of the lipos that cause this or would any smoke damage do it? Thanks.
