BitHed
11.24.2009, 11:30 AM
I just checked the HPI website, and the 5B tires are 170mm dia - what is the diameter of these?
5B set up would require switching to 24mm hubs, though. I sent an email to HPI to see if those hubs will fit the Savage outdrives.
JT you can use the 5T Savage hubs that take the Baja rims if you have the EXTENDED axles from the XL and the 5T 24mm hex adaptors...You also need the XL dogbones to fit the XL axles...(this also cancels out the possibility of using 8mm buggy axles)...The XL bones means you need the XL diffs and the XL dedicated bulkheads :) this counts me out for right now as i am all X sizes...
...not a cheap exercise and the Baja beadlock weights and the tire weights is kinda scary...I have 17mm Maximzers and dirtbonz (still) and they have added alot of 'noticeable' weight, (though i prefer the beadlock advantage)...
It would be worth a shot if you knew your BL transmission is set up for it...Unfortuntaely mine isnt but i would still love to see this setup in action :)
Thanks for all the news fellas...I still reckon they are a great tire and worth a shot...just make sure they dont go on-road too much i guess :) Certainly enough cmments to make an educated guess at how they go though...Great stuff and thanks for your efforts :)
