11.24.2009, 06:32 PM
Certainly, about 3 times faster if your lipos are capable of supporting a high charge rate (5c for example). The dynamite doesnt look that bad really- its cheaper than the hyperion 606i that has the same overall spec but is limited to 50watts vs 100watts on the dynamite.
Hyperion has better support and more users to advice on setting it up, but the manual for the Dynamite should be pretty straight forward and all the normal settings will be identical ( select lipo, set cell count, set charge rate, hit the start button ) pretty much, so it shouldnt require terribly much thought to make it work for you.
Personal preference...
