NovakTwo
Senior Strategist
11.25.2009, 05:37 PM
Interesting - does this pose challenges for spec classes. Nice idea saves buying bits you don't need.
How would this work for distributers?
About the only challenge would be the rotor; only our 12.3mm can be used for Spec racing. Our 13mm tuning rotor has grooves on the beveled shaft that can be identified without dis-assembling the motor. Our new 1300+ Graded Rotors are 12.3 mm, so they can also be used. (But, are not currently part of this program.)
All of our Spec wound stators have the colored ring/insert, designating the wind, installed. We will be designing a program early next year for distributors(mostly international) who may wish to customize motors for their markets.
Ever since we released the Ballistic, we have had requests for additional wound stator winds. We recently added the 9.5, 11.5, 18.5 and 25.5 wound stators. We also have a couple of "light" winds.
We are working on an additional spec rotor made from higher temp rare earth materials as an option, which we will add to the program later.
Novak Electronics, Inc.
