Slowkrawl
High-Voltage Fetish
Slowkrawl's Avatar
11.25.2009, 08:22 PM
JT is right on this one, alum just loads up the wheel media and you are then effectively using an alum 'coating' to "grind".. not brilliant. Heat is normally carried away from the bonding material/grinding media by the material being removed. A loaded wheel will in fact overheat the bond and bad things happen. This is more an issue for thinner and smaller wheels. A loaded wheel will clean itself slowly when used to grind materials harder than the embedded aluminum. But it's stupid. You won't get a good edge on anything that way. I exploded a wheel my first time with a surface grinder back in trade school... it made a real mess of the sheetrock in it's path and left a massive gouge in the mag table. All I did was misjudge my cut depth.
I recommend either a good silicon carbide stick or better yet a diamond wheel dresser, they should never be used with any junk on them. If only from a balance standpoint.
Also if you think I am full of shit I've been a fabricator/machinist/mechanic for ~20 years. Not greasing the O2 regulator is about the second thing you learn in welding training, right after learning how to use a striker...
No offense krawl, but them's the facts.
No offense taken man. It just sounded fishy to me, but like I said I have heard of weirder things!
Also, we taking bench grinders or angle grinders?
