Nard Cox
n00b
11.28.2009, 11:57 AM
Will do, just checked the software also. It's 1.21 and set it to factory, then updated the cut off to 3.4v. No solution .. will check the connections (in detail) now.
EDIT : Just tried 100 times. It seems that when the tires are of the ground it all works pretty good. But as fast as I put it on the ground it dead. So don't there it's a connection since otherwise it would also cog in the air right ?
All connectors seem solid but they all have heatshrink on it so I can't look 'into' that.
