Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
11.28.2009, 08:29 PM
Originally Posted by speedy View Post
would it be a good idea to lower the forward throttle amount to 80% to reduce power ? or maby lower the start power to medium instead or high ?
Crank the start power down, try low ?
Punch control, if your at 100% you can bring it down a little if needed.
Don't mess with EPA unless absolutely nessasary(thats what the Programing feature is for)
Timing set at Low should be OK
Loosen up the slipper so it slips on high traction surfaces the first couple feet and don't be afraid to experiment with the slipper settings. Try it loosened up, you can always cinch it back up.
