scarletboa
scarletboa's Avatar
11.29.2009, 09:16 PM
if you do end up getting a castle esc, get the mamba max pro. the MM is a little dated and castle is discontinuing them soon. besides, why get a MM when you can get the pro cheaper. the amp capabilities are the same, if not better due to the fan, and it is also has the sensor/sensorless hybrid mode. also, you can go up to 6s with the pro.
