Originally Posted by snellemin
I see your top plate is shorter then the one I have. Did you cut yours?
The honey works good for 5 minutes or so. Either that, or spray down the street with Grape soda.
Mckune design makes a kydex bumper and a 1s chassis for the Genx 10.
Yes i did . It makes the esc fit & eaiesr to remove. Plus it eliminates any binding with the esc wires . what is with the chassis in the pic ?. There is no top plate .
EDIT i seee it is a 1s lipo chassis .
FASTXR
The wings are to there to protect the axel from crashs & also to mount elctronics on if you want more rear weight . Also you can move your body posts farther out for more support of the body .
