rchippie
rchippie's Avatar
12.03.2009, 07:27 PM
Originally Posted by Thomas Porfert View Post
Here you go gents, I present to you the Mamba Max Pro 1s Special Edition speed control. Right now they are not available, we are only taking preorders at this time. The release date is set for the first week of January. Because this is a test run to see if we want to keep this as a normal product, it has not been released to distribution yet. If they catch on as we hope, they will become a permanent product. You can find the details on our website, the price is set at $149.99 which is the full retail.
Please remember that is is the 1s version, so it will not have an onboard BEC. Also this controller will have solder posts instead of wires and will not have a fan or a switch.
Those of you that do not need a 1s version, it is recommend to purchase the normal Mamba Max Pro through the normal distribution channels (IE Mike); it will be cheaper because of retail and MAP pricing and we would rather see you purchase it through a reseller.
Let us know if you have any questions fellas!
Thomas Porfert
Castle Tech Support
I know some people are moding the mm pro to run on 1s . What are the advantages or dis advantages of buying the 1s esc versus modifing a mm pro to run on 1s ?. Thank's
REAL MEN RUN BRUSHLESS
