Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
12.04.2009, 09:53 AM
Check the voltage in each cell with a meter, if all cells are good(they'll probably be at around 3.85 volts per) then it could very well be the balance tab itself. I've had to replace many balance plugs due to a failure. If this is the case it's a cheap easy fix (2.00) requireing a new plug and soldering.
