Unsullied_Spy
Unsullied_Spy's Avatar
12.04.2009, 02:00 PM
Originally Posted by Drifted Demon View Post
Guys, i think i may have the same problem. Just got a balancer today, chucked it on & wouldnt balance. I will remove the heatshrink on the end, but what can i use to reseal the end over, i dont have big/wide enough heatshrink. I really want to get this thing balanced so i can use it for sundays racing....
I'd just take the heatshrink off at the end and there is a thin plastic piece that covers the end, take that off as well. From there you can inspect the soldering without completely taking off all the shrink wrap. I need to buy new shrink wrap for mine because I took it all off, but you should be able to remove just the section coving the solder tabs and PCB.
